Thanks for all the replies.
Carm's suggestion to give 'er a few whacks with the hammer sent me to the shop to try it out. I used the ball end of my ball peen and compared the resulting marks to some red brass hex stock I have along with a couple of samples of more yellowy brass. The result of this ball peening test is pretty dramatic. Thumps that produced easily seen marks about 3/32 to 1/8 inch diameter on the other brasses didn't even mark the mystery metal. So on that basis I'm going to assume, for safety's sake, that it is BC.
The airborne dust issue was a new caution for me. The reason they used at work for taking away the BC screwdrivers was that they could splinter if broken and that the splinters may enter the skin and stay there unnoticed for long enough to leach through and into the blood stream. Correct or not that was the reason given for collecting them up and sending them away. Then I find that some of you had a variety of tools made from the stuff.
Ngriff, when you were turning the material did you use any gloves or other protection than usual to aid in avoiding slivers from the chips?
Reading around in some online material I've found (bob_s, that BrushWellman link is one of them) I've come to realize that it can be safely turned. And regular handling of it is fine. Washing up before eating much like with handling lead is probably a wise idea though. But as noted how does one dress down the end when it mushrooms? That is if it mushrooms at all. The stuff is crazy hard. Not cold chisel hard as mentioned but if I beat it against some mild steel I'm thinking the steel would suffer the damage instead of the BC.
And since the stuff is at least somewhat risky what in hell do I do with the chips from turning? I'm not the sort to just put them in the trash if it's a known harmful product in that form. Will it stay stable in a landfill? Ngriff, when you did that turning what did you do with the chips after cleaning the machine?
The intent for this 1/2 inch diameter x 12 inch long bar was to turn it into two fairly stout non-marring punches to use for drifting rifle sights and similar uses. But the stuff is so hard that I'm not sure it would qualify as "non-marring" in any event. So I think I'm just going to mark it as possible BC and see if I can find a home for it with someone else unless I can learn more about it.
Anyhow, once again thanks all. This place is a treasure chest of knowledge and experience.
