Question about using a boring head on Aluminum
  • Question about using a boring head on Aluminum
    Is it common to have long stringy chips
    when boring out a hole in aluminum?
    I'm using ground carbide at about
    1000 rpm
    The hole started out at 1" going to just
    over 2" it is leaving a nice finish though.
    That is fairly common.
      Grind in, add, a chip breaker
        A boring head functionally is hardly any different from boring on a lathe... it's more unstable and less rigid, of course. But in terms of the cutting action, it's virtually identical, so yes - you'll get long strings. It would take a very aggressive chipbreaker to get C's and 9's off of aluminum.
          The usual cheap flat top boring tools? If so then yeah. There's no chip breaker on those. If you were using an insert bar in the head that had a proper chip breaker design for aluminium it would be all small pieces.
          Chilliwack BC, Canada
            Yes it is common. Especially in if you use HSS.
            You will most likely not be cutting heavy enough to break chips.
            You would also not be cutting at a high enough speed and deep enough to take advantage of chip breakers.
            Just make sure you clear the the built up edge off the tool. It will affect the finish and cut a little deeper.
              I've got a set of shars on order for the
              boring head, they should be here next
              week.
