I have an old sheet metal brake. Very old (1920s). It has no modern design features and many of the adjustments are fiddly. But it will bend 12 gauge steel 3 feet wide and it fits in my shop.
The problem I have on this machine is that many of the bolts used to make the necessary adjustments are in holes in which the threads are worn to the point where the bolt hardly fastens. The obvious solution is thread inserts, but I would rather not have to buy kits in the three sizes I will need, plus I don't really like thread inserts anyway because the inserts sometimes unthread. Also, some of the holes are near the edge of a casting and enlarging the holes to accommodate the insert tap wrench may make the section between the hole and the edge of the casting too thin.
I'm not too bad with a torch, and I have lots of brazing rod and flux but some of these castings are pretty large and I worry that putting all the localized heat into the area around a hole could crack the iron upon cooling. And I don't have any practical way to preheat the bigger castings; i.e. no oven big enough.
Are there any other options I'm not considering?
metalmagpie
metalmagpie
