I installed this motor in order to make the adapter for the new motor while waiting for the VFD, but turned out to be too low torque to mill even MDF. The motor I had and wanted to use was a 1.7KW AC servo motor, with the same size of the original motor. I bought VFD that was, in theory, capable of driving this motor, but I couln't get it working, so I finally bought a second hand 1.5-1.8KW 3 phase induction motor. Installed it with MDF and made all the final parts in aluminium. I actually messed up the pulley, made the bore 25mm while the motor shaft is 24.... I will have to make a new one in the future.
In the last picture, you can see the encoder disk I made from aluminium sheet stock. I probably won't use it, I will install an absolute magnetic encoder on the motor.
