Saw, welder and shop scraps toe jack design
  • Saw, welder and shop scraps toe jack design
    Hi Everyone,
    I noticed a bit of discussion on making a toe jack so I thought I would throw in my 2 cents worth.
    Around the same time, I needed a way to lift our house off of a rotting sill and also to lift a 7 ton diesel generator set for moving. I was quite busy and didn't want to do any machining. I also did not want to put any stress on the jack body because I didn't know how much weight I was going to have to lift with the house. Soooo, here is what I came up with:
    I found I had to add the small feet in the front to resist a tendency for this to tip into the load. Because some of my machines have things like electrical boxes down low I didn't want to put any inward pressure on them.
    More details in next post..........................
    Best wishes to ya’ll.
    Sincerely,
    Jim
    All the angles are 2 X 3 X 1/4 and the square tube is 2 X 2 X 3/16. The basic frame is 13 inches tall. The base plate, 6 1/2 X 5 1/2 X 3/8 thick:
    The handle is just 1/2 EMT. I had to add the shoes (pointed to in red) because once in awhile the slide assembly would catch on the added feet on its way down.
    These last shots are just to show more views of how everything fits together:
    Sincerely,
    Jim
      Just for grins, here is the generator before it was moved
      And at the start of the move:
      Had to squeeze through a doorway w/o hitting a large electrical panel. The 4X4 is oak and was a pry bar to wiggle the genset sideways on the rollers as needed:
      One more post ...................................
      Sincerely,
      Jim
        As soon as it was through the doorway and clear of the electrical panel, the rest of the move was quite fast:
        I just had to spin it around on one roller so I could hook the come-a-long to the other end of the building:
        And pull it into place:
        To give more perspective of the size of this genset, I'm 6 feet tall and not a burly linebacker type:
        Not to bad for a 66 year old fart working totally alone for 6 hours.
        Sincerely,
        Jim
          Good job, I bet that deeetroyt sure sounds nice!!
            Thanks!
            I never heard this one run. The next step was to lift it out of the building but problems arose with the contractor so I pulled out of the project after this move.
            Sincerely,
            Jim
              That's brilliant Jim, it's good when things can be done your own way, design is food for thought aswell...
              Thanks for sharing...
              Chris....
                Love love love the Detroit.
                -Doozer 3-53na
                DZER
                  We had several of those generators in our GM plant to cover heat treat departments. The electricians fired up the V-16's every Friday. Cool machinery.
                    That looks really great. I had seen it mentioned on another thread, and I wasn't sure what a "toe jack" was. Good job!! Very clever!!--Brian
                    Design engineer
                    Barrie, Ontario, Canada
                      Amazing. The union hall would have sent at least 4 guys.
                        Perhaps that was at root in the disagreement - worked too fast/too 'easily', leaving the contractor needing to justify the sizable price quoted to the owner.
                        jhe.1973, thank you for not only the toe jack details, but also photos of another one of the moving projects you have undertaken.
                        It is a trival matter in the overall context of your post here, but I am wondering whether you would speak to the manner in which the contours of the angle legs of the slider section were cut to provide clearance for the jack body.
                        A combination of handheld plasma with a guide used for the straight lengths and drills/hole saw for the radii?
                        Originally posted by jhe.1973 View Post
                          Very nice jhe.1973! Thanks for pics.
                            We need a thumbs up icon.
                              It is a very nice job, you did good there,
                              Mark
