What's this shop-made tool used for?
  • What's this shop-made tool used for?
    Approx 7"x 1.25" x o.5 in. Remains of red indicator fluid means it was made by a machinist, as were other things from his estate. Fork halves at end were made from cobalt steel as indicated by remains of markings I see but not visible in pix. Reverse side identical except you see the other ends of the 6 slot-head screws. What does it do?
    It could help with deburring the edge of that ruler shown in your pic.
    Looks to be a scraper of some sort, judging by the residue around the tip of the V, and might be useful for deburring cut sheet stock.
      http://www.10pt9.com/Gear/Tools/ISSF...auge-p560.html
      Probably not, but close
        I would guess edge deburring as well, or a weed puller lol
          It's an Irish large bodied fish disgorger.
            Not sure its meant to be handheld. If I were to make a handle it sure wouldn't look like that.. Maybe held in a vice?. JR
              wire stripper?
                draw through knife sharpener.
                  Thanks, yes deburring an edge makes sense, especially in light of his use of cobalt steel for the vee.
                    It's a small child paddle - the end is used to twist your nose - sometimes even your ears if you were really bad - my dad had one
                      It is to take the sharp edge off freshly guillotined sheet metal. Just a touch on a fine grinding wheel restores the sharp edge. The clever feature is making the edges from two pieces of steel to produce a perfect "v".
                        That explains a lot A.K.!!!! I will have to be more considerate of you in the future now that I know the reasons for your abnormalities!
                          I'd hazard a guess at its a setting guage for somthing, somthing round perpendicular to a face
                          Mark
                            Have to admit considerate would be nice for a change - but Grandpaw always said even abuse is at least some form of attention
                              Hey, I have been downright nice to you lately!
