I am building a DC-DC converter to take 12, 24, or 48 VDC from lead-acid batteries, and provide nominal 140, 280, and 560 VDC for the DC link of a VFD. I'm using E55 ferrite cores, type N27, and I plan to use about 80 kHz square wave from a full bridge. I have some Litz wire to use for the windings: 105/40 (#20 AWG equivalent), and 7x3x21/40 (#14 AWG equivalent). I tried to wind the primary first, using four windings of 3 turns each of the #14 AWG, but I was unable to get enough heat to melt the insulation, and the wire was too large to solder to the terminals of the coilformer (bobbin). But I decided to bring the leads out for direct wiring to the PCB or a terminal strip. I was able to tin the leads to some extent by using liquid flux and the iron set to 480C, and I put two windings of 5 turns each for the primary:
The #14 AWG wire should handle about 15 amps, and I was able to apply a 30 volt square wave to one winding with only 50 mA of magnetizing current, so it should be good for 24-28 volts from two batteries:
I plan to add another pair of windings so it should work on 48V and 30 amps (1500W), 24V and 60 amps (1500W), or 12V and 60 amps (750 watts). However, I really need to tin the leads properly, to make sure the insulation is melted off all the strands, so I have ordered a solder pot:
http://www.ebay.com/itm/391024009808
I also ordered about 2 pounds of 63/37 eutectic solder:
http://www.ebay.com/itm/182285866372
But I may also get some lead free Sn96.5/Ag3/Cu0.5 bar solder for about $20:
http://www.ebay.com/itm/322262071733
I found some information on liquid flux and this was recommended:
http://www.mcmaster.com/#7755a1/=14bwt21
Here is information on soldering and terminations for Litz wire:
http://www.newenglandwire.com/~/medi...ion.ashx?la=en
I was surprised at the influence of skin effect at 80 kHz. It is 10.6 mils, so any wire larger than 21 mils (#24 AWG) will have a significant increase of AC resistance. Here is a skin effect calculator:
http://www.hsmwire.com/skin_effect.php
Any tips and techniques for using a solder pot and terminating magnet wire (especially Litz wire) would be appreciated.
