Downloaded the official op manual and found it deficient in the extreme, tells how to adjust the camlock, lube chart, lots of drawings, but no real operating instructions, don'ts, or any of that, unless all that was beyond the 41 page download that's on the web. IS there any better document out there, we sure haven't seen it if there is one!
Detailed ACER 1440G lathe instructions?
Thanks for the reply. We just got one, used, seems in good cond but haven't hooked it up yet. Before I start a "new" machine I like to know at least the basic moves and dont's, like do we change speeds with spindle moving or not moving? What's the neutral setting for spindle, a friend tried to get it there and only got to where there was a heavy drag but said he'd gone thru all speed changes. Stuff like that. We run a Leblond Regal 19" and some things look similar but we're sure there are lots of differences too, and I hate damaging machines or people due to my own ignorance.
Pictures on 't web look like any other gearhead lathe of the size and even has a screwcutting chart printed on to reduce the problem there, unless it is worn off or a much older version than the common pictures. You could get the equivalent manual for something that looks the same off the grizzly site as their manuals are some of the best around. For basic lathe operation google for the freely available download 'know your lathe' book.
Lathe gearboxes do not have synchromesh so always change gear stationary (like an old tractor in case you encounter one) and jiggle the chuck a bit if it doesn't slip into gear easily. Yes I know old cars had crash gearboxes and changed on the move but that assumed they were still in production to provide the occasional new gear.
By the way, based on a post on another forum, do NOT assume the screwcutting or feed gearbox automatically disengages on hitting the end.
Thanks, when I posted I hadn't yet tried to use the lathe. Today we hooked it up and ran it to check controls. It is very much like our Leblond, in fact it almost looks like a smaller copy, basically same controls. So yes it is very typical. The inaccurate thread chart is a concern so we'll one-pass-thread some spare round stock to see what comes from what setting, or maybe someone will share the code.
Hi guys-
Sorry to take so long, I've been away from the shop the last few days. My lathe is a 2008 model. I pulled the compound and looked at the T slot access point. It's at 9 o'clock so I don't run into that unless the compound is straight in line with the cross slide. My threading chart has been right for all the threads I've done so far, I haven't checked them all. I will try to post pics of the threading chart on my lathe soon. On my lathe, the threading rod has a brass shear pin and the feed rod has a spring loaded ball clutch. Mine also has a jog button on the control panel for gear changing. You can poke it to bump the spindle a little to get a gear to drop in.Kansas City area
Interesting, there's one manual for Acer 1440g online, not sure of date but it does have threading charts. I need to compare that with the table on the front of the machine.
Back in '06 there was a long discussion here regarding this. http://bbs.homeshopmachinist.net/thr...-w-14X40-lathe.
Threading tables are on pp. 9-10 of this manual. http://cncmanual.com/acer-dynamic-la...g-user-manual/Last edited by Cannonmn; 10-03-2016, 07:30 PM.
Originally posted by rws View PostMy lathe is the VFD model, the precursor to the V model.
Let's see if I can attach pic of the Acer threading chart on mine. Some has faded but mostly legible and at first glance appears same as one in the online manual. Wonder if I'm interpreting it correctly? Looks like you don't need to manually swap out gears at all for "inch" threading, the levers do it all as long as top and bottom gears remain as shown, 25 and 40 respectively.
But for metric you have to swap out among 7 different gears in the X and Y positions as well as setting levers. And what's the deal with "86" being shown as the main gear but "91" off to the side? If you have to replace 86 with 91 at times, when does that occur?Last edited by Cannonmn; 10-07-2016, 01:25 AM.
Please explain the gear legends 86 and 91 which occur side by side on both metric and inch thread tables on page 9 of the manual. The same image is on the lathe's metric threading chart but on lathe's inch threading chart, there are no numbers in or beside the center gear. 86? 91? What's that mean to the operator?
On the inch threading chart, the 25 and 40 gear are both running off the 91 gear. The 91 is just an idler to connect the other 2. This is because the leadscew is 4 tpi, an inch thread. The number of teeth on the big gears is irrelevant for inch threads.
On the metric threading chart, The X gear at the top is always running on the 91 gear and the Y gear at the bottom is always running on the 86 gear. This provides the differential between the inch leadscrew and the turning of the spindle to give metric thread pitches.Kansas City area
