I play snooker at a place called Bank Shot Billiards. It's called that because it used to be a bank. The vault remains. It's impressive. Due to the machining and the use of a few tons of stainless, I thought I'd share.
There are 24 gears about 5" in diameter. They are driven by the enormous gear. They in turn drive 4" steel posts into the frame of the door. You can just make it out here inside the large ring, towards the bottom... one of 6 bearings the ring rides upon. Note the device in the center of the image. That arm isn't in front of the ring gear; it is a latch and is preventing the ring from turning. You might be able to turn the ring anti-clockwise (driving the posts deeper into the door frame) but you'll never turn it the other way.
Here's a different view. Again note the bearing the large ring gear rides on.
And here's part of the combination lock, or something.
