Today I removed the cross slide screw from my Bridgeport. This machine is a Line-A-Mill and has an optical tracer. The screws are ballscrews. Getting the screw out was not that bad an ordeal except for the last bolt, 1/4-20x3/4 socket head cap screw. Because of its location it took more that 1 hour to remove this bolt.
I had it out once before when I bought the machine about 12 or more years ago. Problem: excessive backlash as the screw and the balls were badly worn. At that time I replaced the balls and that helped some. Now it is beyond repair but I don't wish to shell out the $600.00 or more that a new screw with nuts would cost.
After removing the screw and cleaning it up I put in my lathe between centers so I could inspect it thoroughly. I could be wrong about this next part but I don't think so. I believe the screw is an ordinary Acme thread, 4 thds. to the inch,
with a couple of ball nuts on it. Inspecting each end of the screw where there is little to no wear, it is very clealy an acme. The thread is deep, way deeper than a ballscrew thread would be with no radius.
Has anyone ever seen this before and was it a common practice?? This machine could be about 30 years old.
This evening I am going to check out some ballscrews that a dealer in used machines has on the shelf. Don't know if any can be adapted to fit. If not I will attempt to make a new srew and perhaps new nuts.
Any ideas will be appreciated.
Paul G.
Paul G.
