This was a fun project, even if the first attempt gave less than stellar results. I really like the second, final version. I was so burned out on machining from my July thrash on the vertical engine that I haven't wanted to do any machining until last week when this came up. The total duration of this project was 6 days, including the first version which I wasn't really happy with. It is getting more and more difficult to find projects that interest me. I think I'm up to 23 or 24 finished engines now, 12 of which are i.c. and 11 or 12 that are steam/air powered. I'm tired of building engines. I want to build another interesting machine to drive with my engines. Currently I have the slinky machine, the bubble blowing machine, the ball elevator that appears in the video, a sawmill, a buzz saw, a wood splitter, a piston pump, a gear pump, an oil well "grass-hopper" pump, a pile driver, and a semi-complete marble automation. I think that perhaps I will design and build a "walking beam conveyor" for my next project. They are fascinating to watch, and just different enough to be interesting.
Line-Shaft Clutch
What about building a tractor you could mount one of your engines on? That would involve some cool engineering on your part. Of course I can just imagine you chasing down the tractor on the first test run.
You already have the clutch mechaninism done so really all you would need to sort out would be the differential/rear axle combination. It wouldn't have to be four wheel drive.Location: The Black Forest in Germany
Originally posted by Black Forest View PostWhat about building a tractor you could mount one of your engines on? That would involve some cool engineering on your part. Of course I can just imagine you chasing down the tractor on the first test run.Location: Long Island, N.Y.
