For the most part I've had very few problems doing parting or grooving operations on a lathe. But lately I've had more than my share, or so it seems. Take today for instance, I'm parting off 12 each 1/2" washers, 0.150" thick from 1.75" cold roll stock. I'm chucked up full depth in a new Bison 6" 3 jaw chuck and the material extends 4" from the jaws and the parting tool is perpendicular to the work. The facing and turning operation go smoothly as does drilling the 3" deep 1/2" center hole.
So I'm turning at 85 rpm and feeding the 0.120" insert cutoff tool at 0.0024" ipr. It's clear in short order that something is wrong. Then 3/8" into the parting operation the insert breaks. I install a new insert and finish the 1st washer but I notice the finish is very poor. So I face the stock and start to part another one off. Once again it's clear that something is wrong. Then I noticed that the stock is being pulled out of the 3 jaw chuck during the parting operation, no problem I'll just tighten the jaws.
Well as you probably guessed that didn't help either so I put the 4 jaw on and finished the job without issues.
So, assuming the 3 jaw chuck is tight and everything else is ok what could cause the material to be pulled out of the chuck when parting? The only thing I can think of that might cause a problem is having the stock extending 4" from the jaws. But the material is 1.75" in diameter and unlikely to flex. I don't think my feed rate was too aggressive and my spindle speed was about right. Even if I was a little off on my feed and speed it shouldn't have caused the stock to be pulled out of the 3 jaw.
Any ideas?
Any ideas?
