I have a press, that is designed for swaging bullets. Oddly, the top of the press casting has not been machined. So, I've been trying to come up with a way to true the top, relative to the threaded die hole. The press has a baked on wrinkle type finish, which is secondary to the need for it to be square.
Threading an insert isn't a problem, boring a hole as a guide in the insert isn't a problem. But some form of a cutter to true off the top has me stumped.
