3d print lathe dog
  • keith20mm
    Didn't happen without pictures
    First, Cubify Design does facilitate creating threads, internal or external, of whatever profile.
    One creates a profile and then uses a helix cut or helix extrude to create the thread.
    I happen to use Makerware, which has no problem printing such a thing.
    As to the pictures, here is a video, for the faithless.
    https://www.youtube.com/watch?v=3YQd5cNJwL0
  • winchman
    Three WOOFS for the lathe dog.
  • elf
  • EddyCurr
    Can your set-up print an approximation of the threads? Or do you still have to resort to tapping these?
    Edit: On rereading, I see nuts were employed. In time, in time ...
  • EddyCurr
    That will have been an entertaining use of skills and resources.
    Well done.
  • keith20mm
    started a topic 3d print lathe dog
    3d print lathe dog
    I needed a 10mm lathe dog to turn a pulley on a skinny, 10mm arbor.
    Made the arbor, supported on centers, glued the pulley stock round onto the arbor (shaft) using super glue.
    Only dog I had was about 3" diameter cast iron.
    I needed a little one, and didn't want to wait for tool supplier to ship, nor, for that matter, to even go to the trouble to look a part number.
    So I modeled up the lathe headstock, less chuck (D1-4), and a dog that would enter into a chuck retainer hole, drew it up using Cubify Design, printed the dog and its clamp. The two holes take 1/4-20 HHMS, taking 1/4" lock washers and nuts.
    Place pieces of sandpaper between the jaws to grip the shaft.
    Works great.
