Bought a small ruby stone from China
  • Bought a small ruby stone from China
    They weren't mucking around with the packaging! Stone is 10 X 10 X 100 mm. Wasn't broken
    I recently received a 4"x6"x10" box containing a single 12" hacksaw blade.
    I hear and I forget.
    I see and I remember.
    I do and I understand.
    Confucius (孔夫子)
      From Amazon? Amazon send me big boxes with almost no padding. I've had more damaged stuff from them than anyone else.
        My 4 x 6 x 10 contained a cell phone battery.
        Regards Ian.
        You might not like what I say,but that doesn't mean I'm wrong.
          Building a laser or watch bearings?
          Helder Ferreira
          Setubal, Portugal
            Odd I bought some gershwein slips from the US recently, the thin ones are fragile or brittle I should say, at the same time there was a faithful tools "offer" at the builders yard, an 8"x3" double sided diamond sharpening plate, and a rubber stand for the same for £19, I thought that's ok, so gave it a go, never used as big a diamond stone before, one side is 400 and the other 1000 grit, OK here goes I thought, let's try a chisel, picked up a modern Bhaco chisel with no edge, to be honest bhaco chisels are soft as ****e, but against all odds I put a really good edge on it, well pleased, even better on good hard steel like a sorby.
            I think I'm going to invest some more in diamond, though bigger stones are going to PE spendy I think.
            Mark
              Ups has a deal with the post office so now UPS brings light Amazon packages & the poor lady from the post office prings the 80# boxes of lead, steel, etc in her car. I really feel bad but it wasn't my stupid idea.
                yes, what are you making? I've been looking a making jewel bearings, but there are issues with grain and direction apparently so it doesn't crack.....curious what you're doing with it.
                  Um, I think he said ruby stone, A 'ruby stone' is not a 'ruby'.
                    Sorry to disappoint, but kendall is right. It's just a fine stone to be used as-is. StefanG used one in a recent video. Skip to 23:08
                      Was it folded in half?
                        Didn't know about using a ruby stone for polishing. I found some on MSC, and they are actually made from aluminum oxide:
                        http://www.mscdirect.com/product/details/05942909
                        Another source seems to have the real McCoy, made from sintered ruby, for about twice the cost:
                        http://www.gesswein.com/p-10226-degu...ones-fine.aspx
                        USA Maryland 21030
                          It's the gesswein stones I bought from the US recently, I had my old ones since the early 80s, if you take care of them they last well, I keep mine in a leather chisel roll, flats squares triangle and round, and of late diamond ( I use wet as I found dry kills them, I use lapping fluid, think it's mineral oil myself) they are without doubt the best stones I've ever used, there are cheaper but no way as good.
                          Mark
                            Originally posted by PStechPaul View Post
                            Didn't know about using a ruby stone for polishing. I found some on MSC, and they are actually made from aluminum oxide[.]
                            -Technically, proper rubies are also made from aluminum oxide.
                            Doc.
                              Diagonal in the box.
                              A squared plus B squared = C squared
                              4*4+6*6+10*10=inside of box
                              16+36+100=152 length inside box
                              12*12=144 length of saw blade
                              easy fit but uses up less than 1% of the volume
                              Confucius (孔夫子)
