With that depth and aspect ratio, you're going to have troubles! Not only with machining out the annular ring, but then also with the threading (I'm guessing you mean an external thread on the 3/4" diameter section, yes?).
If the part could be made in 2 pieces and assembled after threading, you'd make the whole job *hugely* simpler.
Ian
Ian
