Originally posted by stefang
View Post
Precision magnets!
Eh? How come we never had any such excitement when bulk erasing stacks of 1" audio mag tapes all on aluminium spools?
When I placed a 2 inch disk of aluminum on it and hit the power it would fire it good enough to hit the ceiling. The bigger and heavier the aluminum part the more force it produces. The reason it happens is because it isn't magnetic but is a very good conductor.Last edited by Evan; 10-28-2016, 01:53 PM.Free software for calculating bolt circles and similar: Click Here
Originally posted by DEVILHUNTER View PostThese blocks are awsome! I have some magnets left from my 4th axis/lathe headstock direct drive servo motor so I might give a try. Problem is they are quite big so I think that the block would be too strong, plus I don't have a surface grinder yet.
The demagnetizer would be awsome. All my tools are becoming magnetized and I'm getting really tired. The one that gives me more headaches is my mitutoyo carliper, almost imposible to work with it now.
Originally posted by Evan View PostWhen I placed a 2 inch disk of aluminum on it and hit the power it would fire it good enough to hit the ceiling. The bigger and heavier the aluminum part the more force it produces. The reason it happens is because it isn't magnetic but is a very good conductor.
~ What was once an Opinion, became a Fact, to be later proven Wrong ~http://site.thisisjusthowidoit.com
Originally posted by pinstripe View PostInteresting project Stefan. What was your conclusion on the Fog Buster? It wasn't clear if you were using it by the end of the video.
Would you consider one for your mill or lathe?Originally posted by stefang View PostI like it! I used it today on the lathe and its fine there too
Way more reliable than the Noga I had before.
Another vote for the Fog Buster, far superior to other mist systems IMO.
I use mine mostly for drilling, but they will work anywhere and create much less unwanted mist in the process.
DaveLast edited by becksmachine; 11-04-2016, 07:18 AM.
