I've been asked to make a replacement for a splined shaft. It's about 30cm long and has 6-tooth straight sided splines on both ends. Machining should not be a problem, but I am not sure about the hardness needed.
The preliminary plan is to make it from heat treated 4140 which is around 30 HRC. The question is whether it needs to be harder than that.
