I installed the new internet thermostat a couple of days ago. Still need to finish connecting it to the net but am using it as a regular programmable thermostat for now and it works fine. One thing worth mentioning is that it takes a 5 wire feed to connect it to the furnace/central air unit.
Fortunately when I installed central air twenty some years ago I only had a 2 wire setup so I ran the 5 conductor wire. There is a blue wire that is used for a common when you use a internet thermostat so it can use the 24 volts that also runs the furnace.
The thermostat that I bought is a Honeywell and was a little under $100 on Amazon.
