I am building a prototype for a high current (20-30 amp) battery powered DC-DC converter, and I was considering using strips of copper sheet for the high current traces. I found some material in my odds-and-ends metal that is 0.036" (0.9 mm or 19 gauge), but I decided to use bare #16 AWG copper wire. However, it may be good to use some copper strip even for the actual PCB, to avoid wide traces or extra heavy material.
I found some copper flashing at Home Depot that is listed as 3 ounce copper and 0.007" thick, but according to what I found, 3 ounce (per square foot) is actually 0.00375" (3.75 mils). The description shows that it has a paper backing that probably adds to the thickness. Also, the roll is 2 pounds, with an area of 13.3 square feet, which would indicate that it is only 2.4 oz. The cost is about $20/lb.
Here is a chart of common gauges, weights, and thicknesses:
http://www.alascop.com/pdf/sheet_gauge_charts.pdf
Lowes has a 4" x 5" piece of 0.025" copper for $9: https://www.lowes.com/pd/The-Hillman...-Metal/3478155
While searching for information of copper weight and thickness, I found what seems to be a good source of copper sheets and strips: http://basiccopper.com/
They have bargain packs of assorted pieces for as low as $6-$10/pound, and a good range of foil, strips, and sheet from 0.001" to 0.040". Also a nice guide to various gauges and recommendations for usage and tooling:
http://basiccopper.com/thicknessguide.html
For current-carrying capacity of copper strip, I have a wire gauge chart that uses various means to determine what is allowable. For 211 circular mils/amp, a 0.025" x 1/4" strip will handle 23 amps. For 0.24 watts/square inch (for free convection), this size will handle 35 amps.
Here is my spreadsheet for wire sizes and ampacities (including bus bars):
http://enginuitysystems.com/pix/elec...s/WireSize.xls
