Couple things.
1) the angle of the center drill is wrong for you anyhow, so NO need to use it. Hole will be 82 deg almost certainly, possibly 90 deg if european. Drill has 60 deg cone.
2) Transfer punches work OK, but as mentioned, you do need to locate the drill over the punch, MUCH more error there than with the punch. Wiggler, yes, or just use the drill point on a smaller drill for a locator, moving part until drill does not deflect when lowered into the punch mark. An X-Y table on the drill press is the way to go for that.
3) When doing multiple holes, make CERTAIN the "model" and "work" do not move relative to each other. Clamp them together, and use a light touch hammering on the punch.
4) When reinforcing the punch marks, hold the center punch vertical, and tap once lightly to seat it, before hitting it to make the mark. If you don't, then any irregularity of the original punch mark may have moved the larger punch off true center. Have a look at it after tapping, to see if it is OK.
5) Those plates should locate on the large hole, the only reason for the countersink is to clear the dividing head guide arms/blades. So they actually should not need to do much except stop the plate turning and hold it down. Super accuracy is only of interest because the countersink acts as a "competing locator". In a thick plate, button head socket screws would work about as well (in a recess), and only one needs to be a good fit.
