What's wrong with this picture?
  • What's wrong with this picture?
    http://www.ebay.com/itm/Jacobs-Chuck...EAAOSwCGVX~Tt~
    Stu
    Idiots.... Look who's selling it. Not one familiar with tools I'd guess.
    Pete
    1973 SB 10K .
    BenchMaster mill.
      That is definitely a custom shank! It needs an end mill shank to fit in a mill, right?
        It is quite possible that someone carefully ground a Jacobs chuck taper on an old endmill and did a decent job of it.
        It's also quite possible it was ground on a bench grinder and hammered in.
        Who's gonna take one for the team and find out?
          If not for use, then for the wall as a conversation piece!
              Stupid people shouldn't be allowed to own tools.
              JL........
                Just think how lucky you would be if you bought it as the ad states, it comes with a "custom made 3/4" shank"! You'd have one of a kind.
                Bill
                Being ROAD KILL on the Information Super Highway and Electronically Challenged really SUCKS!!
                Every problem can be solved through the proper application of explosives, duct tape, teflon, WD-40, or any combo of the aforementioned items.
                  Drat! The ad says "May not ship to Canada". Just my rotten luck!
                    Hi,
                    I tried to bid at 10 seconds. But my connection timed out and I missed. I thought it could be a great conversation piece.
                    Dalee
                      Originally posted by dalee100 View Post
                      Hi,
                      Dalee
                      For $30 you can make your own conversation piece and still have enough money left for something useful.
                        I have a large floor model Delta drillpress. One of the older ones, vintage probably in the '40s or earlier. I got it when my employer junked it after many years of continual use. I have had it myself for forty years or so. I was surprised to find that instead of a MT by JT adaptor, at some point someone installed an MT by junked reamer adaptor. Chuck runs true and does not slip. I left it as found as changing would offer no improvement.
                        A custom shank made from a single end end mill might not be such a good idea though.
                        Jim H.
                            Now I HAVE seen everything.
                            Why? I mean even an idiot would find it easier to use a piece of 3/4" rod instead of an end mill cutter.
                            I wonder if he was trying to mill it out to accept a piece of rod and the end mill just got stuck in it. I have a tooth where the dentist was doing a root canal and the reamer (they call them points) broke off in it. He couldn't get it out and it is still in there. I guess he didn't have EDM.
                            Make it fit.
                              Why? Why not?
                              It's already a piece of scrap, dead hard, and probably ground better than a tenth. Plus, it might even have a center hole in the back (useful for many things in my experience)
                              Looks like the work of a resourceful and humorous toolmaker to me! That it, if it was done properly on a OD grinder.
