got an angle grinder that runs backwards!
  • #16
    I'd turn down the threaded shaft, build it back up with weld, and turn a lh thread on it. Then make the corresponding Lh nut. I can think of quite a few times I wish I had a grinder that spun the opposite direction. I've already got 6 grinders so if I got 2 free and one spun the opposite way, I'd think of it as a blessing in disguise. The electrical how's and why's an AC motor spins backward are beyond my pay grade. Of course your needs may be different.
    • #17
      It's metric!
      olcop
      • #18
        If you decide to use it, make a pin, bolt or other failsafe device to lock the nut, brush or wheel on so there's no way it will unscrew or you're screwed.
        • #19
          Runs the wrong way? Simple fix...turn the plug over.
          Errol Groff
          New England Model Engineering Society
          http://neme-s.org/
          YouTube channel: http://www.youtube.com/user/GroffErrol?feature=mhee
          • #20
            We had one at the shop a long time ago that ran backwards. One of the guys pressed the shaft out of the armature and pressed it in the other end and it ran in the right direction. So basically what he did was turn the armature around end for end.
            All we could guess was it got messed up at the factory somehow.
            JL...............
            Seems like that would require the brushes to be moved to the other end as well....
            • #21
              Originally posted by HWooldridge View Post
              It's dangerous to use with any threaded wheel so I'd get rid of it.
              Or you could run it on a battery with a transformer to get the voltage up and swap polarity.
              You can't run a battery through a transformer.
              • #22
                Or stand on the other side!😀
                Sole proprietor of Acme Buggy Whips Ltd.
                Specialty products for beating dead horses.
                • #23
                  i am a lefty ,send it to me !!!!
                  FORD BEATING JAP CRAP SINCE 1941!! CAROLYN JONES(1930-1983 actress)may this lady never be forgotten.
                  • #24
                    Probably the stator is in 180 degrees off.
                    • #25
                      No, hang it under a shelf.
                      Originally posted by Beazld View Post
                      Or stand on the other side!��
                      • #26
                        Sheet metal workers working with ventilation pipe often have their grinders changed to run backwards to direct the sparks away. Well, at least they did 25 years ago, I don't know if it's accepted anymore.
                        • #27
                          Well, you can if you swap polarity frequently enough.
                          WI/IL border, USA
                          • #28
                            The fix here is simple.... reverse the wires to the brushes. That HAS TO work.
                            If it did NOT work, that is because it was not done, or not done correctly.
