I picked up some street signs some days back, bus route signs. Steel, and the right gauge for a lot of what I would be using it for. They are not so large that I'd have a problem handling them in my shop for cutting, etc, yet large enough to supply several typically sized pieces for various projects. And they were cheap. It was a good score.
Most of them have a stick-on reflective strip stuck to each side. Question is how best to remove those. I'm sure the adhesive is similar to what licence plate stickers have on them- in other words a waterproof and very tenacious glue. This can be dissolved with an appropriate solvent, but usually the strip itself is durable enough that the solvent takes too long to get through, or never does.
I'm thinking about putting them in the oven, then mechanically peeling the strips off, followed by using a solvent to remove the glue. Whether I then remove the paint or just scuff it up for repainting- depends on the application. I could simply belt sand to get down to bare steel, and I'd be fine with that, but I know how glue tends to stick in a belt and render it useless. I don't mind wasting a belt or two, but I think I'd rather remove the stickers and the glue before deciding what to do with the paint that's left- either nothing, or belt sand it off.
I don't have a blast cabinet, but size-wise my oven can handle most of these.
What would you do?
What would you do?
