Is this surface plate worn or dirty?
  • Is this surface plate worn or dirty?
    Does this look worn or dirty? I'm not buying it, just wondering.
    Also, what's the hole for?
    Impossible to tell if it's worn from a picture. The discoloration could be just oil or some other staining, or even natural to the stone.
    The hole was probably for an indicator post or something.
    JL..............
      Looks worn to me. If recently scraped there should be polka dots of shiny points all over, not areas of shiny surfaces. That doesn't prove it's not usable. It needs comparison against a known good surface to form a judgement about that.
        Probably both worn and dirty, as it looks as if it had been used. Obviusly dirty, and used, so worn.
        TOO worn? No clue.
        Hole in middle probably for a post for some specialty measuring setup.
          -"Scraped"? You don't scrape granite. Granite plates are ground, and then then lapped to repair.
          But I agree, the differences in appearance could indeed indicate wear. You simply cannot tell from a photo, you'll have to closely examine/measure it in person.
          Doc.
            Lots of bicycle frame builders put posts in them (whippings posts) to hold the bike frame by the bottom bracket (crank bearings). Some even build off the plate... that looks to me like brazing char on the plate.
              Looks like a cast iron plate to me. Looking down into the hole, it only looks like an inch or so deep.
              Lynn (Huntsville, AL)
                Hard to tell, looks like cast iron to me as well, it would be three inches thick if it were granite.
                Also, look closely at the lower right hand corner.
                  if its a plate its not granite. Is it a plate? likes somewhat like a welded frame around it, but hard to tell. need more info and photos
                    Thanks all. It was advertised as a granite surface plate. No other photo or details. It did cross my mind that it might just be a block of granite, but I didn't notice how thin it looks in the middle. It could be a shadow, but it does look very thin. It was going cheap at $100.
                      Doc.
                      Right. On the other computer it looked like a metal plate.
                      Sorry about that, Chief!
                        Ok, it's granite, but no way is it a surface plate.
                          Cheaper new at $40.
                          http://www.wttool.com/index/page/cat...gory_id/17550/
                          Make it fit.
                            Bear in mind that pinstripe is in Oz and prices there can be very different than they are in the US.
                              They sure as hell are here, I would love to be able to buy granite plates at those prices.
                              Monarch 10EE 1942
