I am needing to drill some small holes (1/16) down the edge of thin material. approximately 4-5 inches. My question is - how thick does the material have to be (stainless or aluminum) on each side of the drilled hole? ie - how strait will the drill drill?
assuming i can spot / start / align the holes accurately (not a problem)
I am planning on doing it in at-least 2 steps. standard 1/16 drill - then switching to a longer drill to finish the job.
Thoughts? .01" each side? .02"? more?
sam
sam
