I've been playing around with sharpening my worn end mills again. I usually get back into this when the weather turns bad.
Some of them, both 2 & 4 flute, center cutting and non need to have the gash re-cut. I couldn't do this last year because I didn't have the right diamond and CBN wheels. Now that I do I'm finding huge differences in the gash angles, they are not all a standard angle. I have cup and saucer wheels with angles 30, 45 and 20 degrees. What I've done so far is just use the wheel that matches the gash angle, or is the closest. I don't think gash angles are super critical so if I change some of them a bit it s it going to matter?? It also get tricky when you have to get the center line perfect. Any do's or don'ts??? I'll post some pics of my set up and progress at a later date.
Thoughts........
JL.................
Thoughts........
JL.................
