Has anybody ever cut their own gear racks on a vertical milling machine? The quill travel on my machine is only 3", but the head moves up and down, so with some careful measuring the head could probably be raised/lowered incrementally to cut longer racks. I have a complete set of gear cutters 24DP. and have cut many gears but never a rack. I have purchased lengths of rack (they aren't horribly expensive) but I'm curious as to whether anyone has made their own.---Brian
Cutting gear racks on a vertical mill
I have made a 4' rack but in all honesty it came out a bit rough, I cut 6 teeth them asked a bit of commercial rack as an index by clamping on top and advancing the rack one tooth at a time, it worked but my cutter was not brilliant.
I toyed with making racks on the lathe, imagine a rack then make it a round bar, ir was actually quite promising, it was easier to make the tool. The pinion was very like a rack worm if that makes sense, internal radius was the bar radius, I was making an arbour press so the rack was the ram at 2" diameter
If I had a suitable head I'd try the mill again, I need a 90 degree drive or horizontal head.
Mark
Jim--On the set of gear cutters I have, the largest cutter goes from 137 teeth to rack. The larger a gear gets in diameter, the less involute there is to the toothform. You are right. However, the gear cutters take that into account. That is why you can't cut all different gear diameters with one cutter.Brian Rupnow
Design engineer
Barrie, Ontario, Canada
I fully understand that. Take a look at a true gear hob however, it will cut all tooth counts and is not involute form. Take a look in Machinery's Handbook at the basic rack of the full depth involute system. It is straight sided.
Even if it required a modified shape, it still would be much simpler to produce an end mill of the appropriate form to cut a rack on a vertical milling machine than to modify a vertical milling machine to use an involute cutter to produce what would be an imperfect rack in the end.Jim H.
If nothing else, grind a one fluted cutter (easiest in home scenario) with the proper angle and mill your keyway like you would mill most anything on the machine.
Just see what material you cut, as for example cold rolled will end up as a banana after cutting the rack.Amount of experience is in direct proportion to the value of broken equipment.
I'm not talking about a keyway. I am talking about a gear rack.---Different thing altogether. I already have a full set of gear cutters. The only limitation on using my largest cutter to make a rack is the limited (3") travel of the quill in my vertical mill.Brian Rupnow
Design engineer
Originally posted by brian Rupnow View PostHas anybody ever cut their own gear racks on a vertical milling machine? The quill travel on my machine is only 3", but the head moves up and down, so with some careful measuring the head could probably be raised/lowered incrementally to cut longer racks. .....
On my present mill the nose of the quill is a bit over 4" in diameter. So the only way I could make a piece of rack that uses the whole 3.5" of travel of the quill would be to make up a LONG arbor. I'm basing this on the fact that the only medium and finer pitch gear cutters I've seen were fairly small. And certainly smaller than my present size mill's quill.Chilliwack BC, Canada
As you describe, on a mill of the style you are using there is need to have a right angle drive on the quill in order to cut a rack of any reasonable length.
Even then to get rack length longer than the Y-axis travel limit you need to lay the rack lengthwise along the table and cut on the Y-axis. Downside is that cutting with the Y-axis removes the ability to use the X-axis power feed ... presuming you have one of course.
Norman
Design engineer
In Post 10, Sir John cuts a rack several feet long in his vertical milling machine using a simple end mill;
Jim H.
