Philipson Contour Sander would it work on Metal
  • Philipson Contour Sander would it work on Metal
    Was wondering if anyone has experience with these belt sanders,I was interested to see if would work on metal.
    Never seen one but would think the proper belt would be quite useful on metal.
    North Central Arkansas
      Interesting,a narrow belt sander with a narrow double side platen,neat.I don't see why it wouldn't with the right belt.
        Odd that there's nothing on You Tube on any sort of Phillipson sanders at all. Is it some sort of new company? Or is it the sort of line that is only sold to bigger factories?
        Seems like a very big and heavy base for a little band sander. But then it looks like most of their sanders use the same base.
        Chilliwack BC, Canada
          Looks totally photoshoped.
          -D
          DZER
            TTT
            Google 2 x 72 belt grinder for a look into metal belt grinders.
            Hal
              Any belt sander will work on metal with the proper belt on it. The concept of running the belt over a curved or tubular platen instead of a flat piece of plate is a great idea. It opens up a new way to finish inside radii on curved work.---Brian
              Design engineer
              Barrie, Ontario, Canada
                Does it not look to be made out of PVC drain pipe?
                -D
                DZER
                  Made in England since 1968 sold threw Dalton-Wadkin should be good stuff.
                  That what I thought when I seen pic of one couple years back.
                    -D
                    I saw that too. I strongly suspect it's got something to do with dust collection. I also wondered if they were running the belt up inside the tube. But that would require some sort of metal guides to avoid the belt burning into the plastic. So I think it's just and up to small roller and back down again and the tubing is only for dust collecting.
                      Here is a pic of the platens,they are 4 different sizes flat on one side curved on opposite side.The Pattern Maker that design this is a genius.It allows for internal sanding,I think the remove able plastic vacuum system could be replaced with metal tube.
