Trav-a-Dials on a Chinese lathe
  • Trav-a-Dials on a Chinese lathe
    Some years ago I bid on a pallet load of material at a State surplus property auction. I needed the hydraulic control valve that was one of the items on the pallet. The pallet also contained several unopened boxes that I assumed to be other hydraulic components. To my surprise, my low bid won. When I got the loot home I got another surprise. The sealed boxes did not contain hydraulic fittings. Instead, they contained brand new Trav-A Dials. Since I had no use for them at that time, I put them in my attic with intentions of selling them on eBay at a later date. Fast forward 20 years, and they're still in the attic. Also, I now own a 13 x 40 Chinese lathe, and would like to install the Trav-A Dials on it if that is a possibility. However, I have no idea of how to go about it. I hope someone on here has done it, and will be kind enough to tell me how to proceed. One of the dials has to be intended to go on a lathe since it says Cross slide on it's face.
    Lewis Grizzard
    Will this help?
    http://www.southwesternindustries.co...Procedures.pdf
    Len
      I need one if you want to sell one.
        I would sell them and use that money to buy a electronic DRO. Electronic is much nicer, my 10ee came with a trav-a-dial and I dont miss it. And my guess is you will get enough out of them to buy one.
          +1 for selling them and buying a good DRO.Trav-a-dials are better than nothing,but not nearly as nice as a good DRO.
            Originally posted by QSIMDO View Post
            Thanks for the link, and yes it helps.
            Lewis Grizzard
              Excellent advice. There is no substitute for the convenience, accuracy and ease of use of a good multi-axis DRO on a lathe or mill. Mechanical travel indicators are for Luddites.
              RWO
                Same here.
                  I will sell them if I can get enough to buy a serviceable DRO. Pm me if you are interested.
                  Lewis Grizzard
