I bought it out of a bucket of them at the local electrical supply, then they was gone. The imprint says FASK or TASK, but if it's the same as Task Tools they've changed their logo. I love this thing, especially loaded with hex's like here. Random access, easily seen bits, good torque, you can push one out partway to see if its the right one for the screw before actually pulling it out, and being standard 1/4" size, you can use any powerdrive length bits, or any extension, or any 1/4" ratchet for the bit. Without a bit in the end you can throw it in your pocket without damaging clothing or self. There's an item called Teeny Turner that's close but not the same. If only I could find it again! So if you've seen it...
