How often do you run into oddball thread sizes?
  • Originally posted by Mcgyver View Post
    Maybe we should start including fraction metric threads, just to piss the French off "That needs a 15/16cm x 3/4mm thread"
    I still don't see why I should have to deal with their problem in 1789. Especially with them being on the other side of the ocean. I've already got everything I need right here. I'm well aware of and fluent in scientific (greek) prefixes. Too bad everyday life doesn't need them. If I'm feeling feisty I can always take one-seventh of a mm for a feed rate.
      As long as I can make them on a cnc lathe, I suppose most any pitch is possible. Never mind the French. I'm wondering what the Brits were thinking with their Whitworth thread series. The 55* included angle is odd enough, but 4 1/2 inch nominal with 2.875 threads per inch?
      • Originally posted by PeterAus View Post
        Have you tries looking at BA threads for that 3/16 or 10 gauge screw maybe its a 1 or 2 BA https://www.royalsignals.org.uk/articles/threads.htm
        Hi Peter, I appreciate the reference but a replacement screw was made long ago to fit.
        Chilliwack BC, Canada
        • Originally posted by Dan_the_Chemist View Post
          It's not an oddball thread size... but it's related.
          I got tired of my younger brother stealing my large spanners. So, when I needed to make a large nut for a tool, I made it and paired it with a spanner that won't tempt him.
          A friend of mine had 5 sided "Security Lugnuts" for the wheels on his Miata.
          • Working on some post war Lionel trains. 6x40 thread pitch screws...
            • Originally posted by RB211 View Post
              Have you seen the BSME (or just ME) thread series? "British Standard Model Engineer"
              Got a set of taps/dies for same off eBay a couple years back.
              Rather interesting series because they have constant pitch:
              Every diameter can be either 32 TPI or 40 TPI...
              Fun for playing with shop-made mics
              Pretty cheap too, less than $120 for a set from India.
              I think the flank angle is 55deg, Whitworth form.
              • No one but him? Likely as not, they would just grab a pipe wrench.
                Originally posted by Willy View Post
                I like that proprietary 7 sided nut. Talk about oddball fasteners!
                No one is going to tighten or loosen that puppy but you.
                Make it fit.
