Surface grinder shaft question
  • Surface grinder shaft question
    I just got my 1st Surface Grinder but is only came with one balance Wheel Adapter. I am looking to get a 2nd or third adapter to allow quick swaps of a wheel.
    So are all the mounts standard? Am I better to build my own using my current adapter as a pattern?
    http://www.ebay.com/itm/F320-GRINDIN...YAAOSw2GlXK5B4
    http://www.ebay.com/itm/F350-TATUNG-...gAAOSwiLdV9v6C
    Find your grinder here.
    http://wmsopko.com/adapters.htm
    Gene
      Not found on the page:
      Acer Supra 618 Surface grinder
      I had no clue there were so many types? WOW. I think I'll end up building my own before I am done.
        Sopko doesn't make hubs for every machine out there. Most of the small machines are a 1" taper but I've found that there can be some variance from that standard and the slightest bit means trouble.
        The other thing is I don't like popping the hub off the taper every time I want to change wheels. On my KO Lee it's a PIA to try and get one hand behind the column and down below the motor mount to hold the spindle tail with a wrench and at the same time try and reach the front of the spindle with another wrench.
        I came up with a better system, almost done with it.
        JL...............
          Standard surface grinder tapers are 7 degrees per side and 1" major diameter.
          They can be easily made, just don't forget you need left hand threads which probably means you need to single point internal threads.
            ..and... on some the thread is non-standard.. like my Brown and Sharpe. Call Sopko... they will likely have an adapter even if they don't list your machine.
              In my 30+yrs. of experience, I have never needed to balance a wheel for my 6x18 Boyar-Schultz. I have used only 3 or 4 Norton wheels over that time, so I cannot say about other brands. BTW, the Norton 5SG wheels are superb.
              RWO
                Used one in class 30 years ago. I would assume that balancing to mount would be needed per stone. The biggest rule I was taught for Surface grinders was CLEAN everything before mounting. One speck of dust is bad.
                Tapper mount allows remounting to the same tolerance each time. Un-mounting the stone means resurfacing a stone each remount.
                  I have a DoAll 612 size machine, and with 150 grit wheels I found balancing to be the only thing that would lead to good finishes especially in soft steels.
                  Sent from my XT1053 using Tapatalk
                    Andre3127. I would think with soft steels you would be better off with 46 or 60 grit wheels. I only use 150/180 to pick out sharp corners or hold a fancy shape when form grinding. The high grit number wheels can tend to burn the surface. Dressing technique is essential.
                      Wheels require frequent dressing anyway, so what's the big deal??
                      JL.....................
                        Just about every wheel I have ever had was out of balance, some more than others and by quite a bit.
                        Rarely do I get a wheel that is in perfect balance.
                          JoeLee
                          Are the rods on the balancing tool hardened? Ground? It looks shop made?
                            The balancing stand rails and the arbor are 5/8" hardened and ground. Supposed to be straight within .001 per ft. The rails are 5" between posts. The 4 posts are 1" dia. SS.
                            Yes, shop made. Still working on the hubs.
                              They'e called "hubs" or "wheel hubs"
                              Here's a DIY wheel hub video in two parts
                              https://www.youtube.com/watch?v=N9_7XvLFcNM
                              https://www.youtube.com/watch?v=dLEbaRqk9RU
                              Making grinding wheel hubs is mostly simple lathe work but Stefan has laid the process out step by step to aid the noob.
                              A balancing frame and balancing arbor is not big deal to make but it has to be done accurately so the frame edges are straight and in the same plane and the arbor is straight and the journals cylindrical. You also need hard surfaces so they will roll freer.
                              Make a half dozen including a hub for 7/8" dia wheel bores with large flanges for mounting cutting disks
