Swivel heads for shop made machinist jacks?
  • Swivel heads for shop made machinist jacks?
    Where can I purchase these? I am making a few jacks and can't find these?
    Thanks
    Galaxy S4, Slimkat
    If I wasn't married I'd quit fishing
    McMastercarr and search "Vibration-Damping Swivel Leveling Mounts". May be other alternatives on their site as well under fixturing/workholding.
      Carr-Lane tooling components. www.carrlane.net
        Or Jergens: http://www.jergensinc.com/
          Make one from a ball joint?
          http://www.banggood.com/M10-Spare-Pa...l?rmmds=search ($4)
          or, as suggested:
          https://www.mcmaster.com/#swivel-leveling-mounts/=15ydepj
          https://www.mcmaster.com/#swivel-lev...ounts/=15ydfwp
          USA Maryland 21030
            not directly answering your question, but they're not hard to make.....ball and socket: a ball bearing silver soldered to the end of the threaded section sits in bored recess forming the socket. A tiny bit of peening locks the socket - because its hard to hold i've done it with vise grips Just squeeze the edge of the cup
              Or use a cylinder that the ball end goes in and turn a grove for an O-ring to keep the foot on the ball.
                You could use a ball-end mill to make the socket, insert a steel ball with a threaded hole or shaft, and cut an internal groove to hold it in place with a spring clip.
                USA Maryland 21030
                  I left the bottom of the bore a cone, I don't think it matters that its not round unless a key function is smooth movement. The KISS method.
                    At least one maker of c-clamps makes replacement swivel pads for their clamps. I just can't remember which ones.
                      So, I did a search.
                      https://www.amazon.com/Wilton-C-Clam.../dp/B002EY3ZVG
                        They're really not hard to make. The majority of my C-clamps are flea market finds. The ones without the swivels are usually heavily discounted, so I have made over a dozen.
                        Do yourself a favor and see if your TV carrier has America One News Network (AONN). 208 on Uverse. It is good old fashion news, unlike the networks, with no hype, bias or other BS.
                          Thanks folks. I'll try and make my own. If that's fails I'll make a purchase.
                          Galaxy S4, Slimkat
                            why not use these (they cost almost nothing, hardened):
                            https://www.brw.ch/1/BRW-ToolShop/1/...CategoryId=700
                            360340, 360360, second page
                              The last time I made a set of swivel head jacks I used the pistons from hydraulic piston pumps. Gave them away in 2005 though
