Painting old machinery
  • #16
    Originally posted by polaraligned View Post
    “2K” or “Two component” is any product that uses a hardener, activator, catalyst, etc. It may or may not use a third component in the form of a solvent. 2K products don’t “dry” like a 1K. The 2K product “cures” by molecules linking together to form a whole new compound. Most high quality 2Ks are insoluble after a full cure and will not soften when exposed to solvents like thinners
    I disagree with your definition and you will have to show me proof as in something written on Facebook or the Internet so I will believe you. We all know they are credible sources.
    If you thin paint with solvent that in my book doesn't make it a 2 component paint. That would by your definition make any paint even a latex paint that gets thinned with water a 2 komponent paint. ?????
    • #17
      My understanding of the difference between catalyst and hardener is that a catalyst is used with polyester resins (typically used at 2-5%) and creates a chemical reaction which propagates through the resin. A hardener is used with epoxy resins (typically at 15-35%) and creates a new material completely.
      • #18
        You did not read it correctly. It does not say that a solvent makes it 2 part, only that a 2K product may or may not have a solvent. It is a general statement as to what "2K" refers to and to specific to paint.
        • #19
          I restored my A/C 12x36 about 10 years ago. I used automotive acrylic enamel with hardener and sprayed using a HVLP gun over bare metal (like the factory does). It's held up to oil, carb cleaner, WD-40 and degreaser. The only place it's showing "wear" is at the compound where the razor ribbons often hit and/or fly around. I started by applying paint stripper then pressure washing all the parts. The paint stripper not only removed the old paint but also any oil and grease. I then sand blasted a few spots where needed.
          • #20
            Here it is on the homemade bench with a pull-out chip tray.
            • #21
              great stuff guys - thanks - very helpful to a beginner
              does anyone have experience with a ppg product called alk-200? - it is not automotive but industrial - it does use a hardener and is cheaper than automobile paints - it is an alky acrylic enamel
              thanks
              • #22
                What is the difference in paint?
                Originally posted on the HAMB forum by Paint Guru
                Picking the right paint for your vehicle can be confusing and going to the paint store and asking this question can be embarrassing at times to say the least. So here is a quick paint reference for you to decide what type paint fits your preference, budget and skill level. **Note this is not about water-based paint nor lacquer – just solvent that’s easy to buy just about anywhere!!!
                What is 1k and 2k?
                1k comes from the term Komponent (i.e. component). 1k means simply just the paint is required to dry. 2k means an activator or hardener is required to dry/cure.
                What types of paint are 1k?
                Lacquer, Enamel, Acrylic Enamel and Base Coat
                What types of paint are 2k?
                Acrylic Urethane, Polyurethane, Clear coat
                What types of paint have an option for a hardener?
                Every type has an option – however some brands the way they are made – a hardener is not compatible. Look at the data sheet for instructions to see if a hardener can be used.
                What does a hardener/activator do? A hardener crosslinks or bonds the coating to a denser/harder film. This gives durability, chemical resistance and color holdout.
                Enamels:
                There are 3 types of Enamels – Short Oil, Medium Oil and Long Oil Enamel.
                Long oil is what you see in tractor supply stores, home improvement stores etc. They are super easy to get a shine, but have no color holdout. The product fades very quick and chemical resistance is very low. Long oil takes a long time to dry, and can even get retack (gets sticky in direct sunlight). Long Oil in direct sun has a Gloss life from about 6 months - 2 years. Repair-ability is very difficult. The paint rolls instead of powder when trying to sand, when painting on top of it, very high possibility of wrinkles. Usually stripping is the best method of repairing, but with a very low cost – sometimes this is a consideration. Price ranges from about $22-$38/gallon
                Medium Oil is what a lot of heavy equipment is sprayed with. It’s very easy to spray, dries faster than a long oil (but still a slow dry product), a little more durable and only goes through a few retacks. Medium Oil is more solvent resistant and last double the life span of a long oil enamel. MOE in direct sun has a Gloss life from about 1.5-3 years. Repair ability is difficult without an activator. Paint will roll up when sanding and has a very high possibility of wrinkles when using an automotive paint. Usually best to repaint with the same product. Can use VM and P Naphtha to reduce in a lot of moe type paint, which is not a harsh solvent and has less of a possibility to wrinkle. While not as inexpensive as a Long Oil enamel, MOE is still an economical choice from prices ranging from $35-$75 gallon. These can be purchased from specialty industrial store.
                Short Oil is what most all car enamels are. It has a quick dry time, hardly noticeable retack, fast dry times, more durable than long oil and easy to apply. Metallics can be a challenge due to the faster dry times. Short Oil in direct sun has a gloss life from about 1.5-6 years. Short Oil enamels are still inexpensive depending on brand. Prices range from $65-$150 gallon.
                Acrylic Enamel
                Acrylic Enamels are built into Short oil enamels. Acrylic is added to make acrylic Enamel. Acrylic adds durability, quicker cure times, and great repair ability. Acrylic is soft in nature and makes buffing a lot easier. Acrylic Enamel works best activated. A/E in direct sun has a gloss life from about 2-6 years. Has little to no “retack”. Skill level is a little more advanced due to adding an activator, but should be considered. Prices for A/E are the same as a Short Oil Enamel but you have to consider the activator. Price range $65-$150 gallon plus half pint of activator (in most cases) costing from $10-$25
                Acrylic Urethane
                Acrylic Urethane is the standard in the automotive repair industry. It’s the most used due to its great color holdout, excellent repair ability, ease of buffing, good chemical resistance, fast cure times and great flexibility. Clear coats are in most cases Acrylic Urethane and a lot of single stage paints are acrylic urethane. Metallics can be difficult to spray with acrylic urethane. Skill level to spray is more advanced, not as easy to slick out, can orange peel and run/sag. Must use an activator to cure the product. A/U is soft and can scratch with minimal effort, but can be repaired by buffing in most cases if not too deep. Pricing for Acrylic Urethanes are higher than Enamel mainly due to more activator having to be used to crosslink the product. Usually the mixing ratios for Acrylic Urethanes are 4:1 or 2:1. Cost can range from $80-$700 gallon plus activator ranging from $35-$150 quart depending on brand. Durability 4-7 years.
                Polyurethane
                Polyurethane is mainly used in fleet applications where strength and durability are demanded. Polyurethane is the most chemical resistant of any of the above topcoats. It has excellent flexibility, color hold out and scratch resistance. The one downside to Polyurethane is, because it gets so hard, sanding and buffing is nearly impossible after full cure. It’s also slower to dry than acrylic urethane. Polyurethane is a great choice for chassis, under hood, race cars, fuel tanks, engine blocks, big trucks, boats etc. Metallics are difficult to spray in Polyurethane as well. Polyurethane cost about the same as Acrylic Urethanes and mix ratios usually are 3:1. So some shops order 3 quarts of color and 1 quart of activator. Durability 5-10 years.
                Base Coat
                Base coat can be made out of acrylic, polyester and vinyl. Base coat is an excellent choice for metallic colors. Metallic single stage cannot be buffed properly because you actually scratch the flake itself and hard to polish correctly. With base coat you can spray, lightly sand trash out, rebase then after everything looks correct, apply a clear coat. Base coat is very easy to apply, however clear coat, after the 1st coat, can be difficult because it’s hard to see what you are painting. Doing a period correct restoration (pre 80’s) – base/clear is usually not the right choice due to its gloss level. However you can get most any color in basecoat. Base/clear is easy to repair (same as acrylic urethane) however some basecoats if you sand through the clear, will lift and wrinkle and become very difficult to repair. Durability is 3-10 years clear coated and 1 year without clear. Base coat has to be reduced with solvent, usually 1:1 or 2:1, so 2 quarts can get you a gallon sprayable. Prices range from $120-$1200/gallon
                • #23
                  What is 1k and 2k?
                  Enamels:
                  Acrylic Enamel
                  Acrylic Urethane
                  Polyurethane
                  Base Coat
                  Thank you. Great info. Where do moisture curing urethanes like Por15 fit in the scheme of things?
                  Sent from my SM-G900V using Tapatalk
                  • #24
                    very helpful!! thank you
