Originally posted by Mcgyver
View Post
I very much suspect that entirely different things are being done... the watchmakers are likely NOT doing the same thing, so for their purposes the front edge IS important.
My question is VERY MUCH about "NOT overthinking"... Trying to set the perpendicularity of the tool by carefully aligning the very smallest feature on the entire tool seems to be the "overthinking" here..... It seems to involve a number of assumptions, as well as introducing very possible errors, yet it is apparently being touted as the "best and most accurate" method.
1) A slight error of seeing the lineup of the short side leads to a much larger error on the longer portion that corresponds to the depth of the fins. Seems the exact opposite to what you want.
2) There is an assumption that the short edge is correctly at a 90 degree angle to the axis of the cutter. Who says it is?
3) There is an assumption that you can in some way more effectively align a short side than a long side. This seems exactly backwards
4) There is an assumption that it is somehow faster to get out the loupe, with paper and a strong light, proceeding to minutely examine a tiny edge while adjusting the angle, rather than to quickly set the holder against the flat of the chuck and move on. This also seems exactly backwards. I certainly would not find it faster, I would find it quite a but slower. Even using a square seems faster and more effective
Now, the comment is going to be made that the "blade" is dovetailed, and consequently cannot be measured against. But the side of the tool blank can be measured against, so if you take care up front to grind the tool square, you never need to concern yourself about that, if the tool side is square to the work, so is the blade.
Honestly, unless someone can explain this to us as to how it is better, it really seems to be going the long way around the barn, blindfolded and walking backwards. I'm not arguing, I'm just puzzled. Flabbergasted, maybe...
