Ok, have a fence guy coming out and to put in the 5" fence posts he is going to not drill holes and insert but use his fancy post pounding machine. No problem with that except that he will pass about 20' from the foundation of my garage. The block foundation is dug into the hill so I really don't want it cracked.
Understand that post/piling driving and building damage is established science. There are small engineering companies that earn their living by calculating and monitoring construction vibrations so buildings don't get damaged.
I know of one case in central Ohio where a coworker had a big truck drive down the street about 100' from his house and periodically stop and slam a big weight into the ground to set up ground vibrations that could be measured by a company searching for oil. Shortly thereafter he and several others on their street found cracking in their basement foundations. Left that contract soon after so don't know how his discussions with the survey company went.
So, any anecdotal stories of bad things that have happened with a fence post driving project. I'll even take one where it was the father of your cousin's girlfriend that lives on the other side of the country.
