Help salvaging a Kurt D40
Originally posted by ALee View PostIt appears to be an older model and doesn't match up with the model on the Kurt website.
What is going on with the apparent drilling/peening damage at the end of the nut (Item 7, p/n #D40-3). Is it possible that this has damaged the threads in the bore of #D40-3, locking it in place on Item 16, p/n #D40-5A Screw? On second look, the threads of D40-5A are visible - the damage may just be from careless use.
Originally posted by ALeeIs the locking collar threaded on?
Edit: Item 15, p/n #D40-217A is a Spiral Retaining Ring. If you clean well and look closely, the outer end of the spiral should be visible and there ought to be a reduced section at the tip which is useful for getting a purchase with a small flatblade screwdriver. Wear eye protection then start by extracting this tip and proceed by winding the remaining portion of the SRR out of the recess.Last edited by EddyCurr; 02-04-2017, 05:06 PM.
Looks like someone has already applied pliers or a pipe wrench, going by tooth marks visible on the circumference.
The retainer nut is threaded on, removing it should allow you to push the screw and nut assembly out of the body. The screw being bound up in the nut is a common issue, usually due to galling. It can a really bear to get it loose if at all. Turn it upright and soak with a good penetrating oil (not WD40 lol). Go from there...Mike
Central Ohio, USA
Thanks for everyone's suggestions. I'll try soaking with penetrating oil. It just seems odd that Kurt would design a threaded locking collar without flats for a wrench. I don't see how I'm going to get it off without marring the surface.
Any ideas if it is left or right hand thread?
Sent from my HTC6525LVW using Tapatalk
It won't be the marks that jammed it, the screw doesn;t reach that far inside. Just jammed.
If you can get the plug out of the other end, and fill it with diesel and some oil it may loosen. Or wait a bit here and someone will suggest ATF and.......................4357 2773 5647 3671 3645 0087 1276
"There's no pleasing these serpents"......Lewis Carroll
great suggestion
I had a similar problem with a Kurt vise. In my case the threads were gunked up with dried coolant. So I soaked the whole vise in water, taking it out from time to time to work the screw back and forth. As the water dissolved the dried coolant, the screw started moving more and more until I finally was able to run it all the way out, then clean everything thoroughly. If I remember correctly it took several days. The water has to slowly work its way along the threads.
I would definitely never use an impact wrench on it. Patience has less chance of damaging anything.
Originally posted by john hobdeclipe View PostI had a similar problem with a Kurt vise. In my case the threads were gunked up with dried coolant. So I soaked the whole vise in water, taking it out from time to time to work the screw back and forth.
I would definitely never use an impact wrench on it. Patience has less chance of damaging anything.Or a lil heat from an air heat gun.
I also like the idea of an impact wrench to shock the "sticktion" more than a big wrench just applying a constant force.
When I say impact wrench I am talking about liberal use, just small wacks at a time, not full throttle and see what breaks first.
Thanks for posting your predicament, looking forward to see what the fix is. JR
I offer my thanks also....
I do not have a Kurt, but now I see how they are made, always wondered about that, and you answered the question I never asked but wanted to know about. Photos perfect!4357 2773 5647 3671 3645 0087 1276
