I would like to modify a motorcycle cush drive for a custom wheel swap...I need to cut down the drive dogs. Obviously a mill would be best, but mine is not running yet.
Can I turn this in the lathe? Each drive dog is going to strike the tool, and I'm worried that this will damage the tool or my machine.
The machine is a Southbend 10" using 1/4" tooling...far from the ultimate in rigidity...would this be considered abuse? The material is aluminum (cast I'm pretty sure).
I hope I'm clear describing the problem...if not, consider a square and each corner smacking the tool as the work turns. Only in this case there are five drive dogs arranged symmetrically around about a 5 inch diameter circle so my tool will be smacked five times per rev as I face the dogs down to proper length.
Thanks for your time and help.
