Clausing Cooling Pump Wiring?
  • Clausing Cooling Pump Wiring?
    I recently purchased a Clausing Colchester 15 50 1979 model. It was wired for 440V and after some investigation we found the main motor was set for Delta so we wired it for 220 delta and it works great. The cooling motor is 220/440 on the label but no wiring diagram, I have the original books but no wiring diagram for the either mail or cooling. Any one had the problem?
