Choice of steel
  • Choice of steel
    All:
    I have a 1.5"x6" hunk of 4140 HT which seems to machine like mild steel (disappointed) . I'm re-building a vise lead screw and I require a reasonably hard material. Would I be better off using a water hardening or oil hardening (annealed) tool steel instead? I don't have facilities for heat treatment and I'm really short of funds so sending parts out for heat treatment is not an option.
    303 Stainless is good for shafts, easy to machine. "Relatively" hard without any heat-treating, and has anti-galling features.
      It DOES machine well. But you may notice that it wears out HSS pretty rapidly.
      It will likely work OK for your screw. And wear less than annealed un-treated O-1 or W1.
      1144 is another material that machines super and yet does not wear that fast.
        Yep 1144, I use stress proof for pretty much anything I don't need to weld. It can be hardened too.
          The 4140 HT is a good choice for that application. It machines well, but is pretty tough.
            Are you sure it's HT or "annealed". Annealed will machine very much like gummy 1018/A36.
              Another vote for 1144 Stressproof.
              It is around Rc32 if I recall.
              Turns, mills, and drills and taps well.
              -Doozer
              DZER
                -Doozer
                speedymetals says 24-26Rc depending on the diameter. I never tried it but will have to some time, its often recommended.
                http://www.speedymetals.com/information/material36.html
