My tool gloot
  • My tool gloot
    Small 110 volt Sitter kiln. $50.
    Gary Davison
    Tarkio, Mo.
    It's official... YOU SUCK!
    Brilliant score! I trust we will soon be salivating to threads about you heat treating all manner of parts and tooling in this new kiln?
    Chilliwack BC, Canada
      Now if I should run across one like that for $100 I'll feel like I'm getting screwed!!!
      If it was raining soup I'd get a fork.
      JL.................
        Scorching hot suckage! I'd love to have one of those (in 240V, please) Well wear.
          Yeah, very suck. So how did you get it so cheap?
            You win. You also suck. So it's a win-win.
              I did a quick conversion, calculating the 110v vs 230v mains in SA and then $50 to $14 per ZAR rand and after some number crunching to assess the value of your find I have determined that ... Jip you guessed it ..You suck... Now I feel even worse about my 2 days spend trying to get a old kitchen oven to heat up to 600C ... Great find ...enjoy
              You can always just EDM it...
                It was advertised for $100. When i went to pick it up the fellow said he plugged it in and it did not work and wanted to know what i would offer. I offered 25, he said a little higher. I said 50 and he accepted. Deal done.
                The control does not work, but the elements are good. It'll be fine once I install a digital controller.
                Gary Davison
                Tarkio, Mo.
                  When he checked out the kiln did he engage the "kiln sitter" on the front there? It would require a cone to be placed inside.
                    Well done ... good score.
                      What is the maximum temperature in Fahrenheit?
                        Normal ceramics kiln would have max temperature of about 2350F.
                          No, He had no idea how to operate it.
                          Gary Davison
                          Tarkio, Mo.
                            With a digital controller, your choice!!!!
                            Gary Davison
                            Tarkio, Mo.
                              So, how exactly does that thing gloot a tool?
                              Nice find though.
