Greetings all;
I bought a small 1 hp (real 1 ph - 13.2A, motor plate: http://i290.photobucket.com/albums/l...psym6moe3k.jpg ) twin cylinder compressor off eBay about 10 yrs ago. Seller poorly described the item and I guessed looking at the images that the motor was at least a 3/4 hp. Won the auction for just under $5 and paid the seller an additional $4 just cause I felt sorry for him. THe comp was old w/o electrical controls - instead there was a pressure switch that unloaded compressor valves when the comp reached pressure - motor ran all the time the unit was plugged in. I liked it enough to add conventional controls w/ a pressure activated relay and pressure release valve for starting.
This machine has always needed to be on a 20A breaker. A 15A with no other activity on it would trip when the pressure reached about 70 psi in the tank. Fast forward 10 years of occasional use and now it is straining while running and trips a 20A breaker around 80 psi. Not a breaker issue as I have experienced this on 3 separate breakers in two separate locations.
I presume the single capacitor is start only and is not used for run - correct? Motor has no issues starting. Motor has slip rings and centrifugal switch - I presume to drop the cap out of the circuit - correct? Looking at the cap, I see what might be a bulge in the top of the cap - looks to be a tar top - not sure if this is a bulge or just how the unit was made. http://i290.photobucket.com/albums/l...pscvslmn6x.jpg If not, what range of capacitor is reasonable for 1 ph - since the cap size is worn off of the cap can. http://i290.photobucket.com/albums/l...psubg0h83r.jpg
I figured on putting a smaller drive pulley on the motor - I am guessing that the drive pulley was a bit too large from the get go. With the small tanks, it builds up pressure very quickly and for how I use it a slightly slower fill rate would not be an issue. After removing the belt to remove the pulley, I could hear a dry sounding bearing so I took the motor partially apart to access the bearing (on the pulley end).
Sticking my finger into the opposite motor shaft bearing it fees smooth and not dry. If I decide to replace it, is there anything I need to be aware of before dismantling the contacts for the slip rings? http://i290.photobucket.com/albums/l...pscvslmn6x.jpg My very limited motor dismantling is limited to universal motors w/ brushes and one 3 phase; I have never dismantled a motor w/ slip rings before.
