evidence of a nice tram
  • #16
    Is that a D-series head? Is this the one you just did some work to last winter or fall?
    • #17
      no it's a 2 liter CRV
      I do allot of honda's but way more subaru's when it comes to head gaskets due to them always popping a cork on the 2.5 liters,
      one thing I can say about the 3 piece steel is the heads don't go as warp crazy when someone has a serious overheat,
      and also when the gaskets do fail they tend to give allot more early warning signs, sometimes even allowing someone to finish their vacation trip if they know what to watch for or nurse it around town for awhile till they get some funds together, not so with the old style, was like a damn letting go in short order...
      • #18
        How flat do the mating surfaces have to be? .0001? .001? .005?
        • #19
          I won't disagree with the basic idea of what you are saying. However, if you have a head resurfaced at your local automotive machine shop you will most likely NOT see a crosshatch pattern. Ignore for now those platen / belt sander type machines. Millions of heads have been resurfaced on the 570 Van Norman Rotary Broach or many brands of surface grinders. Common wheel diameters 15" to 18". These machines are all set up with just enough tilt so that the cutters or grinding wheel DO NOT drag on the back side so that they DO NOT leave crosshatch. The reason being that the machines would have to be much longer and heavier to allow full coverage of wheel to sweep entire length of head / block. Think of a 6-71 Detroit head or maybe an old straight 8 engine. In the case of surface grinders-- you may sometimes see traces of crosshatch showing up when the front of wheel comes off the head under heavy grinding. This means you are forcing the process and the grinding head is riding up and dropping back down when the front cutting edge travels off the cylinder head. If this is allowed the head will not be flat! Many of the grinding machines rely only on the weight of grinding head and gravity to keep it running true on the ways.
          I'm not going to do the geometry and math to say just how many "tenths" dish shape these machines leave across the width of head but it's of no consequence.
          • #20
            This is for full length - it's .002" sounds like ample le-way till you consider if it's width its much less and also the compound errors of the block come into play, that's my main concern as like stated some hack took an abrasive wheel to it, some of these errors can be within less then an inch so even more critical than width...
            " If warpage is less than 0.05 mm (0.002 in) cylinder head resurfacing is not required.
            If warpage is between 0.05 mm (0.002 in) and 0.2 mm (0.008 in), resurface cylinder head.
            Maximum resurface limit is 0.2 mm (0.008 in) based on a height of 132.0 mm (5.20 in). "
            If you see any "mechanic" using an abrasive wheel on an engine block and esp. an aluminum engine block do me a favor and biatch slap him right on the spot...
            so much quicker to remove the easily removable thin membrane material with a good well tuned scraper and you don't ruin somebodies entire engine... arms still sore from stoning that block in...
            • #21
              This is why im so P.Offed
              I see this all the time, this is after stoning my arss off - you can see dug in evidence on the engine block at the lower bridge section,,, there are tons of "mechanics" still using this "practice"
              they should all be rounded up and quarantined from society in a special little place --- kept far far away from anything mechanical - no real chance for re-hab but maybe start introducing them to simple things like wheel barrows and such so that they may become more self sufficient, I don't think they should technically even be allowed to use a typical shopping cart as the rear swiveling wheels are far too complicated for them to comprehend the effects of steering, better to have one foreword wheel as it's of far more simpler design...
              Iv matched up the gaskets critical sealing area's to the lower bridge and have total contact in the crucial area's
              please don't tell me I should "do it right" and pull the engine and tear it all down and put it on the mill because it would then be worth more than the vehicle is...
              • #22
                Wipe on a very thin coat of hondabond around the water and oil ports, both sides of the gasket. Copper spray around the cylinders again both sides of the gasket. She'll seal up good.
                • #23
                  I know you've probably had good luck with that Andy but I try to get within specs and then leave the rest up to Fel-Pro,
                  I remember warnings at least by them not to jack with using additional sealants on their membrane material, they do claim even with their three piece steel gaskets that they are designed to cover your butt should there be "imperfections" in the mating surfaces, have had good luck with them for many a decade, additional sealants may or may not help with holding back the fluids like oil and coolant - but when it comes to combustion pressures the rest is up to the gasket itself,
                  some pics of my precision valve spring compressor
                  Mills are so dang versatile, usually just do the little 1600 cc heads pushing by hand with a T-handle but these two liters have a little more spring.
                  this is not my best mounting effort but it sure was fast, going to end up with a huge dummy mark on my table one of these days...
                  • #24
                    OT: I would suggest that if you can not see the cross hatch pattern in the photo in the first post, then your computer's monitor may need some adjustment.
                    Originally posted by A.K. Boomer View Post
                    You should see this pattern every time you mill a cylinder head - if you don't then don't bolt it together,
                    This is not evidence of a "perfect tram" because fore and aft tilt of the head could still be way off, although that you will notice in your first "skin cut" and it's also no where near as critical and really means nothing for sealing capabilities,,,
                    However the crosshatch pattern does, the side to side crosshatch is evidence of a very good tram and you should see this pattern every time, very critical esp. with todays very unforgiving three piece steel head gaskets,
                    if you do not see crosshatch it means only one thing - that you have dished the center of the head length wise, so the extra critical bridge area of the head gasket that does double duty for sealing off combustion gasses/pressure is far more apt to fail.
                    I know for many all the above is quite obvious but thought id post for the ones who have not been around engines much and such...
                    Too achieve good results always tram your Mill with a wider swath then the actual part you want good results with...
                    • #25
                      Memories, Sometimes that was my job after school in early 1960's.
                      The heads of the Diesel tractors and cars went away for a head job, and the block stayed in situ
                      with its studs sticking up.
                      The job was to clean up the block surface, and also the piston tops,
                      with an old file hand ground with a curved end.
                      Removing metal was strictly prohibited. The clean up was done with a compressed air spray gun
                      with a mix of kerosene and gasoline.
                      I recall sitting for too long up on top of a stinking old tractor outside of the shop,
                      on a hot afternoon in the sun, thirsty, with a sore back and too hot.
                      Imagine today's kids doing that?
                      • #26
                        On diesels to boot - I bet ole Ma told you more than once "I thought I told you to go wash your hands before coming to the dinner table" lol
                        that was way before the days when nitrile or latex mechanics gloves were worn,
                        Be proud of yourself - at least you didn't go around scrapping peoples engine blocks to clean them up...
                        • #27
                          There are times I will still scrape an aluminum block but I do it very methodically as to not dig in, scratch, or gouge the metal.
                          For omc outboards they use a spray on acid to eat the gasket off the aluminum parts.
                          I know the copper spray doesn't do anything for the combustion chamber sealing. I use it for pretty much all "hard" gaskets I install to help seal up the fluids. I have had very good success with it and will always use it when I can. Yes the stock type (bare) gasket does seal fine, but getting seepage because of some very slight imperfection (tooling mark, fine scratch, etc.) drives me crazy, I like to see pepper dry engines/gaskets.
                          • #28
                            Absolutely - I never have a problem with "dig ins" even though my scraper is razor sharp - just using the proper angle and only applying so much pressure,
                            the thin membrane material on these newer gaskets comes off so easy,
                            there's no need for abrasive discs or other methods, scrape once, use some hand held scotch bright everywhere and I try to use a strategic pattern when using it that "dams" the fluids,
                            then it's brake clean the surface about three times applying it to a terry cloth rag first two times then a regular rag last time,
                            even fibers from the terry cloth rag for the last run might cause seepage if trapped.
                            anyways - beast it running and is out the door - onto the next bucket of fun...
                            • #29
                              Ak, I have one of these I use for valve springs, makes fast work of removal and installing.
                              • #30
                                I like to do a wipe with a very clean hand after all the rags and towels. Every towel I have ever tried always leaves some sort of fiber or pieces behind. Brand new towel, shake it out, blow it out with the hose, shake again, wipe, stuff left behind. lol
