You should see this pattern every time you mill a cylinder head - if you don't then don't bolt it together,
This is not evidence of a "perfect tram" because fore and aft tilt of the head could still be way off, although that you will notice in your first "skin cut" and it's also no where near as critical and really means nothing for sealing capabilities,,,
However the crosshatch pattern does, the side to side crosshatch is evidence of a very good tram and you should see this pattern every time, very critical esp. with todays very unforgiving three piece steel head gaskets,
if you do not see crosshatch it means only one thing - that you have dished the center of the head length wise, so the extra critical bridge area of the head gasket that does double duty for sealing off combustion gasses/pressure is far more apt to fail.
I know for many all the above is quite obvious but thought id post for the ones who have not been around engines much and such...
Too achieve good results always tram your Mill with a wider swath then the actual part you want good results with...
