DSG 13/30 oil leak
  • DSG 13/30 oil leak
    DSG 13/30 seemed to be leaking oil from the main gearbox. Main issue was established as the oil filter cartridge wasn't tight enough. While looking at this I noticed two small holes in the gearbox cover at the rear which was weeping oil. Initially i put a couple of self tappers in them to block but then thought these might be breather holes.
    Edit: far blurry screw is the second hole.
    Question is are these original or has someone drilled them?
    [IMG][/IMG]
    Here's a pic of the back of my 13 X 42 DSG
    don't remember any holes there . it bolts down from the top
    Guaranteed not to rust, bust, collect dust, bend, chip, crack or peel
      Don't know what they where put in for. Just wanted to check they were nothing to do with oil breathers etc. I'll block them up.
      Thanks
      Al
