15,000 of these things to modify!!!
  • #76
    Originally posted by sid pileski View Post
    Keep in mind, this is not my full time job. I work 8+ elsewhere as an engineer.
    Then I have to ask, are you doing your customer, or yourself, a disservice by taking the work? Assuming you are charging a living wage to do this job, your customer might be better off grinding them up for remelt, and run a new batch.
    allan
    • #77
      allan
      Not to be flippant, but this ain't my or their first rodeo!
      This is a fair and equitable arangement for both of us.
      Obviously I can't publish all the details, but we've been working together for many years now.
      I'm looking into optimization within time budget vs effort.
      Sometimes ya gotta just suck it up!
      • #78
        Not flippant at all. You are obviously creative and hard working, and know how to take care of yourself. But i can hear your elbow screaming from here
        allan
        • #79
          Customer obviously has already been through a lead time to get the 15,000 pieces. They are not getting the next lot quickly, UNLESS the vendor "owns" the problem, and is motivated to make it good.
          But it is likely that the customer owns at least part of it, because they did not notice the out-of-spec bosses on drawing or samples. In that case, they have to make do until next order. They probably can't get just a few hundred ordered, molding isn't usually like that unless it can be a gang molding situation using interchangeable molding stations. And that takes another customer with the same material in same color.
          It DOES admittedly look like a huge time-eater that will mess up things for the foreseeable, so there is some point to questioning the deal. It will take more than a hundred 30 minute batches of 125 to eat up that backlog, assuming they don't order another corrected run meantime, and avoid the added cost. Odds are they will just order more and swap over when they come in.
          • #80
            Having been in your position Sid, you are doing the right thing, and indeed, Sometimes ya gotta just suck it up. I hope your customer appreciates your efforts and skill.
            I am always amused by all the opinions offered here, about what you should do or should have done. This is not to discourage any of those opinions, sometimes the obvious gets overlooked...
            • #81
              We really need a web counter for this, that will increment when you complete each unit.
              And, of course, a TPS report. With the new coversheet.
              • #82
                I appreciate that Wes. They do appreciate what I do. And, they compensate accordingly!
                After seeing some suggestions about gang drills, I have begun looking into one.
                A member here offered something that he had. But he's on the other side of the country.
                I'll probably make something dedicated to positions, not future adjustable.
                I'll update if I make progress.
                Sid
                • #83
                  I'll probably make something dedicated to positions, not future adjustable. Sid
                  You could start with these:
                  http://www.ebay.com/itm/5-X-Mabuchi-...YdPY-lcZABwQ4w
                  http://www.ebay.com/itm/Motor-Speed-...8AAOSwol5Y0Q3h
                  (This was just a quick look, there's probably something else better out there but it's what I had in mind.)
                  • #84
                    ...After seeing some suggestions about gang drills, I have begun looking into one.
                    Sid
                    I did that once for a deburring operation a few years back when I was still working. The pattern spacing of the four holes was such that I was conveniently able to use spur gears instead of a belt or chain. The speeds and forces were low so when I put it into production they just used it and I never heard anything more about it. Completely forgot about it until just now.
                    Just a thought: When drilling plastic, you might want to add a spring-loaded stripper plate to prevent self-feeding of the drills if there is any flex in the part. Not trying to over complicate, but consider provisions in the design just in case it becomes a problem.
                    • #85
                      Hey Wes, I started a new thread with the gang design.
                      Look it over.
                      Sid
                      • #86
                        Look it over.
                        Sid
                        Yeah, got confused and posted here.
                        • #87
                          Have you considered (possibly ultrasonic) heating to install the fasteners? Something like:
                          http://www.spirol.com/library/whitep...llation_na.pdf
                          http://www.emersonindustrial.com/en-...sertion_hr.pdf
                          http://www.dupont.com/content/dam/du...20Snap-fit.pdf
                          USA Maryland 21030
                          • #88
                            Messing with the housings via heating would not be acceptable in a production setting.
                            You still run the risk of stress and cracking after insertion/cooling.
                            Sid
                            I was thinking something along the lines of delivering the housings to the assembly area on a conveyor that ran past a few heat guns or something similar. Heating would be easy...er than redrilling 60,000 holes I would think...and should get rid of any stresses as well.
