The new CNC mill is going to need a counterbalance on the Z. An adjustable air cylinder looks to be the best way. For now, building a simple cylinder is a must since even used ones on ebay are too expensive. We're not talking about a lot of pressure....would DOM steel tubing be smooth enough on the inside to work along with a simple aluminum piston & a couple o-ring seals with an oiler to keeps things lubed?
This is in the head scratchin' phase now. No need to worry about the tricky regulator & reservoir needed to keep the pressure stable on both the up & down movement; that research will come later.
