I bought some really good router cutters at an auction thought they would go good in my router table although I laid out about a hundred bucks for all of them they would probably cost that each and more I got about seven or eight of them.Problem is half are half inch 12.5 mm and fit the router collet fine the others actually about five of them are just about a millimeter to wide 14mm approx must have been for a c.n.c miller I've been told.They are too good throw away I made enquiries about having the shafts professionally reduced no body wants to know as the router bit heads have profiles which cannot be re-entered in the lathe chuck without damage or being able to hold true and safe.
I suddenly thought a few days ago that if I was to cover the heads with tissue paper then moulded car body filler paste around them then re-entered them into shank end in to the chuck and trued it up so that it could be reversed then the bit with the car body filler (now trued)could be held in the chuck with the shank sticking out and I could remove the millimeter or so as required any ideas or suggestions as to how this could be done better or would in your opinion would it work I figure with the tissue papes acting as a light barrier I could burn the body filler a bit at a time and prise it off Alistair
