One should also factor in the whole mower when making the decision to repair or replace. A lower cost commercial mower that is built by the OEM with an engine that is expected to last 1600 Hrs. will also be usually equipped with either a hydrostatic transmission, or in the case of a zero turn mower, a hydraulic pump and motors to reflect the end price point that the manufacturer is aiming at. Commercial mowers with engines that have a greater lifespan will also have major components that last longer and of course are priced accordingly to reflect that level of quality.
At the number of hours on your machine you are approaching the point in it's life when repairs to other components and downtime are are going to be major factors in it's viability to remain a money maker for the upcoming season. If you are going to remain available to your existing or potential new customers on a regular basis you might want to consider a quick fix to your present unit while it still has some resale or trade in value.
